Make sure your nozzle is clean before you start, after that you must lower the temperature off the filament with 10degrees. And then you try something, just a test file. When you see nothing comes out, you push from the back the filament in to the nozzle, normaly then you push all the stuff that is stuck out of your nozzle.
It’s possible it’s burned and it will smell, but it should work.
Make sure it’s not the feeder that’s the problem rather than the nozzle being blocked. My experience with bronzeFill has been that it’s less likely to block the nozzle than standard PLA, not the other way round.
If for any reason the feeder has not been pushing the filament through efficiently and has been grinding the bronzeFill then there will be a lot of bronze particles “coating” the metal hub of the feeder which creates problems afterwards for either bronzeFill or PLA. These bronze particles prevent the hub from gripping the filament correctly and hence pushing it efficiently into the nozzle.
Cleaning out the feeder periodically is a piece of regular maintenance that I would recommend regardless of what materials you’ve been using. Unfortunately the feeder on the UM2 is not the best of designs, hence why it’s the most re-designed part for it on YouMagine.
I should have said in my post that I’m still using the standard feeder and printing successfully with bronzeFill, but when I get extrusion problems now it tends to be the first place I look for a possible solution.
Did you post this on the Ultimaker forums? There are quite a few people who print with bronzefill no problem there. I love the idea from Steve here that it might be clogging the knurled wheel in the feeder. Compressed air usually helps (or blow hard). Maybe it’s time to print out that IRobertI feeder. My first thought though was that if you are switching between ABS and PLA regularly you are bound to have problems. ABS needs things hotter and the teflon isolator tends to deform which ABS doesn’t seem to mind as much and then you switch to PLA and you have a deformed isolator which causes extra friction (a few pounds!) and you have some bits of ABS in the nozzle slowly caramelizing over the next few hours.
I do a “cold pull” aka “atomic pull” after EVERY filament change to get every last microgram of the old filament out. This means that whenever the printer finishes a print, if I suspect I might have to change filament I immediately set the nozzle temp to 90 for PLA (or 130 for ABS) and shove the filament back into the nozzle while the nozzle is still hot then come back later when the bed is cool and pull the filament out. I still have the original feeder also and this would be easier with the IRobertI feeder.
