With ABS part I use “same stuff” or Ambroid “ProWeld” to fuse surfaces together. Keying if necessary. I got that tip from a tour of Stratasys back in the mid 90’s
Yup. That’s more-or-less the process I use. I wet the mating surfaces with Acetone before I stick em together with ABS/Acetone slurry though, just to soften the surface and ensure the dry surface doesn’t absorb the Acetone out of the slurry to quickly. A good sanding afterwards finishes the job. Spot the joint…
Great to see so many fantastic pieces of software that are making this easier. @MetaCAD do you have any experience of how they cope with thin-walled large builds?
Solvent welding is the best solution I have found. Despite what community trends may lead you to believe, acetone is not ideal for dissolving ABS. MEK (butanone) works far better and is commonly used when assembling plastic model kits. If you don’t have a perfect fit between pieces solvent welding will not produce a strong void-free seam, you need to dissolve some ABS in the solvent to create a glue that can fill the gap. I have also experimented with friction welding (ABS filament in a handheld rotary tool) but I don’t think it’s ideal for most parts as the weld is only on the surface. It has applications, but is more limited than solvent welding.
Thank you @stephan_5 I think this project is really great and shows that innovation can be achieved by questioning, adapting and experimenting with what we already have available.
