Feb 2015
Support material is why I bought an Up! Printer. Support just peels off … It made me giggle with giddy delight the first time I did it. So my Mendel90 (not really but I had a design similar idea the same time as nophead) gets the bigger and faster jobs (current Up only has a 140x140mm build plate) and the Up gets the difficult prints. I can print any shape I like and post processing just requires lots of peeling to remove the support. No Dremel, no sharp knives. It does take a quick mod with a resistor to print with normal ABS (eom filament prints 30c hotter) but this is trivial and not warranty impacting. The Zortrax printers do the same though not sure what mods if any are required to print with non oem
No force needed. lol
Put part into your slicer. export the file as a x3g. then print. Dont even open up the makerbot desktop crap.
Ypu mention that it is easier to remove supports, if you increase the ‘air gap’ between supports and the object.
Do you know how to increase the ‘air gap’ (for instance in Cura)?
Is this ‘Distance X/Y’ and ‘Distance Z’?
Which values do you recommend?
Seconded on Simplify3D. It has configurations for many different printers built in, and it’s not hard to configure for one that’s not. Excellent ability to place and adjust supports, and they do indeed usually just fall away. And, it’s a great slicer.
