Jun 2016
Hi, so I’m printing this vase for a girl I like. The thing is, you can clearly see the 3D print lines and the surface is kind of rough. What is the best way to get rid of this? I am printing in PLA btw.
    Jun '16
    Oct '17
  • 14
  • 34.0k
  • 11
The best way is quite subjective. It depends on the person, the skillset, the budget etc. Xtc-3d by smooth on along with similar two part casting resins can coat a print and give it a clean smooth surface. Priming and painting. Glazing compound. Sanding and polishing with buffing wheel and compound. Rock tumbling with various media and polish. I’m sure wax dipping is a thing though it may warp the PLA…
1 month later
28 days later
3 months later
11 months later
May I ask your detailed procedure? How to heat resin? Use hot water or heat directly? Do you heat the resin before or after mixing the hardender? Thanks.
