Jun 2016
1 month later
Sanding, definitely sanding. But WET SANDING. It keeps the paper from getting loaded up, and it cools the plastic. (If you try to sand PLA too aggressively, it’ll get too hot and the dust loaded up in the paper will actually fuse itself back to the part, making it feel all crusty!)
Here’s what I do: just have a tupperware type container or some other sort of small bucket or tub on your workbench with water in it, and keep running your sandpaper through it to rinse the particles off, periodically dunking the part, wiping the part off with a towel, and wetting it again… Obviously you’ll need sandpaper that can take being wet. (I use 3M Wetordry, their automotive sandpaper…another benefit of this is it’s manufactured to produce a much more uniform scratch pattern.)
If you’re printing at 0.2mm or smaller layers, you probably don’t need to start with 2xx (200, 220, 250 are common, depends on brand) grit and can get away with starting at 400… Then it’s 800, 1000, 2000. If you want to get really super-shiny you can try 3M Trizact in 3000 and 5000 grit. (You should be able to achieve a mirror finish at this level.)
Of course, this is just if you want to polish up something printed-in-color, as-is… Painting is a much more practical approach, because a good high-build automotive primer can take most of the work out of surface prep. Example: (Skip to 2:57) Prop: Shop - Mister Handy Scale Model Build - YouTube 258 (Although this is about making a mold master from a 3D print, you can skip the molding/casting and just paint it at that point…you get the idea.)
28 days later
3 months later
I have been having a lot of success with warm Epoxy resin on PLA (I haven’t tried it on ABS as PLA is my primary filament). If you use it directly form the mixing bowl its way too thick. By adding 10 degrees of heat the epoxy starts to run like thin honey. Too much heat and it forms lumpy skins.
An additional process is to use a VERY low power blowtorch - I use those little modellers pen-like blow torches - and wave the flame lightly back and forth over the epoxy resin you have just laid-down. This softens the epoxy and smoothes it.
Obviously this doesnt work on smaller or thin elements but works very well on everything else. Its easy to sand afterwards.
11 months later
May I ask your detailed procedure? How to heat resin? Use hot water or heat directly? Do you heat the resin before or after mixing the hardender? Thanks.
