Apr 2016
We’ve been struggling to get support material to work for many days now. So, I thought I’d query the hive mind of 3D Hubbers to find new things to try.
We print our models mostly in PLA because it doesn’t shrink like ABS and we don’t need the temperature resistance. PVA looks promising because it dissolves quickly in water. HIPS is cheaper but the solvent limonene is more expensive and an irritant. Our dual extruder is the Flashforge Creator Pro.
This is what failed already:
  • The long times required for HIPS to be dissolved damaged PLA models 85.
  • HIPS didn’t stick to the glass bed as PLA does.
  • HIPS printed on PLA raft didn’t stick.
  • PLA model printed on PVA support didn’t stick.
What else can we try?
  • BaronWilliams suggest to print PLA support under PETG 109 or vice versa since apparently the 2 don’t bond together like PLA under PLA and can be clipped off more easily.
  • print PLA support under PETG 56 and dissolve the former but it uses nasty chemical (drain cleaner)
  • lfenske asked about support material for PETG 62 but got no detailed answers yet.
  • Airwolf recommend ABS with HIPS 19. Maybe we should change from PLA to ABS because it works better with HIPS. In any case, we had trouble getting HIPS to stick to the glass bed.
  • Maybe we need to print PVA/HIPS extra slow onto the raft or the glass bed to get it to stick? So far we’ve been using standard settings that work perfectly for PLA.
I really hope we can get that to work since peeling of PLA support under PLA models is a pain in the…
    Apr '16
    Apr '16
  • 9
  • 17.1k
  • 5
Hi jasu,
which temperatures did you target when printing with PLA on PVA support?
We actually have very good results using those two filaments together!
We use T-PVA and PLA filament from corix3D on a helloBEEprusa dual-extruder.
Running on a heatbed with 3M blue tape @50°C and filament temperatures both @210°C
works pretty well for us.
I hope this will help you in some way…
Cheers Daniel // IT4Race GmbH
Yup, I use my PVA glue on the glass to print both PLA and PETG with no rafts. It makes a huge difference. I would expect it to work well with PVA filament too. HIPS im not sure about as I havent tried printing it myself, but I would say its definitely worth a shot. I make a mix of 5 parts water to 1 part PVA glue, put a small blob on the center of the bed (maybe 2-3 ml) and then spread it around evenly with a cloth. If you apply it to a hot bed it dries in minutes. I then give the surface a quick wipe with methylated spirits to remove any greasy finger marks before each print. The PVA film lasts for many prints without needing to be reapplied. I also run my bed a lot hotter than you which might be relevant. I print PLA at 80degC (which gives me about 60degC on the surface of my glass) and PETG at 100degC (so about 80degC on the print surface).
