Hi I’ve got my A8 for fairly Long and it was working fine. But after some prints it didn’t Finish the prints said that the Stepper was disabled. At the begining that happened every 5-10 prints. But at the end it happened everytime. After a few failiures the printed stopped working. The LEDs in the mainboard didn’t light up but the mainboard was getting power so Ist changed the mainboard. Didn’t fix it neither. Now I need help
tkuan
Was the LCD on? If it is on, does it display anything? Was the problem only happens during printing?
tkuan
4
Can you communicate with the board via terminal(via Cura 1.x, Octoprint or Arduino)? If you can, it should tell you what is wrong. I am assuming the printer halted during printing, because you have a faulty termistor on heat bed or heat end. You can use M190(heat bed) and M109(heat end) commands to troubleshoot.
gikam
5
all steppers are disabled?
No the printer isn’t showing up on my PC.
it only Said stepper disabled Not how Mandy
