I am making some parts to clamp one pole to another where the pole sizes are different and I need a leveling system. I am making these in ABS but having the usual warping issues since the parts are large and thick. PLA is out since it won’t handle the heat!
The part needs to handle direct sunlight (heat) and cold weather. I don’t care about fading etc. just structural integrity. Weight on the parts won’t be significant but they will be bolted together around a pole so there will be some compression.
I don’t expect the parts to last forever but would rather not replace them every other month!!!
Nylon might be the way to go, though I have no personal experience with the material. - I do hear it is a bit difficult to dial in, but it shouldn’t warp and is stronger than the other stuff I see mentioned. Again, I don’t have proper information on how it stands up to cold, but I do know it is resistant to ambient moisture, which is an important factor.
Then there’s the new CPE+ material from Ultimaker (don’t know if other’s make it) that is both hard (without being brittle) and temperature resistant.
What about PETG? I’ve printed some outdoor parts, although I can’t tell you yet how they will weather as I haven’t had them long enough. PETG is used for bottled water, it should be pretty weather resistant.
ASA - as supplied by RigidInk is UV tolerant (Not tried it yet, but will look into it, once I have gone through my stash of sample filaments from the TCT show !
Looking into this a bit and finding mixed reviews on printing. Main thing is warping. I can’t seem to get a feel for how it really is doing since comments I am finding are all over the place on this.
I am tempted to try it but at $50+ a roll it is up there.
If lifting off the bed and warping are less or more controllable than ABS then that is a start especially when making brackets or parts that need to fit or bolt together.
