Sep 2015
I tested this idea today and the results seemed to be ideal. I would be interested to know if anyone else had experienced this.
I printed an ABS part, +50 layers, 85C bed, and no lifting on the corners - and it was clean.
After print, it was easy to remove and the bottom of the print was completely clean.
How ? Simple. I found some plastic sheet left over after covering the kids school books.
It’s like vinyl - just thinner and is marked as Removable Self Adhesive Book Cover. Cost was around $2 for a 5m roll.
I cleaned the print bed with Acetone, then laid a piece of the adhesive plastic just larger than the print area I was to print.
I then wiped the plastic with clear plain acetone with the intention to make sure it was clean from finger print oils, etc. The surface of the plastic turned very tacky.
The first layer of the print went down so well, and consistent - far better than I had ever achieved on ABS slurry on the aluminium bed.
After the print, the plastic lifted easily from the print bed - reminded me of those large thin very stretchy wide area plasters used in hospitals when you have an IV inserted. It peeled off the bottom of the print with minimal effort.
Here’s a pic of my first layer print in progress : http://i.imgur.com/e5KVRw9.jpg 62
Update : googled the plastic book cover, and it’s PVC.
And PVC glues well to ABS using acetone, so explains why it turns tacky and accepts the first layer so well.
Update 2 :
as good as this sounds, it has been pointed out that the C in PVC is Chloride and when heated gives off Chloride Gas which is EXTREMELY BAD. I do not recommend using this method.
I will, however, keep looking for alternatives that work as well as this.
    Sep '15
    Sep '15
  • 9
  • 3.0k
  • 5
Nice one, Durban Dave!!
Wouldn’t go much higher than 85 for the bed though. The C stands for Chloride. Don’t want to step into your workshop and take a big whiff of Chlorine gas! :-0
I’d like to give this a go. Are you printing in an enclosed printer?
Funny thing - I’ve seen MEK soften the surface of PVC but not Acetone. :-/
Keep up the good work!
AndyL
Hi AndyL
Yes, my i3 printer is outside and also in a case.
Someone showed me a spec sheet for PVC a few days ago and acetone was listed on that. I also found ABS listed on a tube of plumbers PVC Weld. I had joined an ABS printed female thread to the inside of a 50mm PVC pipe with acetone with great success.
I got the idea from this article which is specifically for abs bed adheston: ABS Bed Adhesion Tips & Tricks | MatterHackers 18 It was saying to use a glue stick or any glu PVA based I had also seen a video where someone diluted PVA and was using that, I tried diluted PVA first that did not work at all.
