3DVS
7
I’ll mostly use it with the SD card.
Other than that, what do you think of the WB2 ?
Not that bad, but my $599 “prusa steel” prints better prints and its not enclosed… If you want I can send you comparisson pics for you to determine the print quality using bq filament on BOTH printers…
I owned 4 witbox1 I ended up selling to buy the WB2 blindly. If i would have known, I wouldnt have bought it but instead seeked alternatives.
BTW witboxes are not meant for ABS filament…
3DVS
10
I’d like to see the comparison pictures!
Thanks for the informations.
ABS is not really a problem for me.
3DVS
11
Thank you for the informations!
Did you had any issues,… ?
Witbox 2 has great features: check it hear: https://www.bqstore.nl/nl/witbox-2/169-bq-witbox-2
We have it, both with the hephestos 2 and can just say, great printer, great service and a machine with good features <2k
I don’t had any issues yet
3DVS
14
Thank you for the advice!
Will see what others have to say / what i still find about it, but currently on the top of my list.
3DVS
15
HI, thank you for your comment!
Have you personnaly used a Mankati ? Like the Mankati XT Plus (still under 2k, large build area, heated bed and dual extruders,… quite impressive).
http://www.mankati.com/fullscale-xt-plus/
I have a Robo3d R1+ Plus and I love it. The only down side is that it is open but I haven’t had a problem with that, I still print abs and everything else under the rainbow all the time. Literally. Between here and Robo3d’s forum you can get questions answered in an hour. They also have great customer service! the build plate is something like 10" x 9" x 8" and sells at $799.99.
If you want to tinker there are plenty of upgrades due to it being open source.
You can print tethered or usb.
The quality and reliability of the Mankati is not great. It is a nice machine for it’s price in combination with it’s specifications. The extruders are still a bit frustrating.
3DVS
18
If I’m not mistaken you also have a ZYYX+, right ?
What do you think about it ?
I tried to react at your other post but Hubs had a bug.
This was my answer about the ZYYX+:
I like the ZYYX+. I print daily with 2 of them and it’s a nice improvement on the ‘old’ ZYYX. The cooling is better and the X-Y construction is more stable. The extruder is still one of the most reliable extruders i ever worked with. The only issue i have is the navigation of the print-file-list on the machine can be a bit slow. And if you want to print a lot with ABS, it’s not the best choice. For strong parts i use Polymax or Colorfab XT.
Another issue can be it’s weight. I do many workshops and it’s a heavy machine.
I’m also happy with Simplify3D, it’s very nice to work with.
My perfect duo at this moment are the ZYYX+ (PLA, Polymax, PC, PET, TPU/Flex) and the Zortrax M200 (ABS, PCABS, HIPS, PET). Try to get a demo somewhere, it can help.
3DVS
20
Ok, thank you!
The ZYYX+ is also on top of my list, but it’s hard to get some reviews as it doesn’t seem a lot of people have it…
I had the same problem. There was one good review in Dutch but i didn’t find an English version. The only thing that i can advise you is to find a Hub, shop or person with a ZYYX or ZYYX+ and ask for a demo.
Hi!
Based on your current criteria, I would go for the Witbox 2. It’s enclosed, not a kit, decently fast, it has a pretty large build volume, and it can use 3rd party filament! Unfortunately, it doesn’t have auto-leveling (I think).
I hope this helps! If you want, click here the 3D Hubs reviews.
additional to Jackson2727, yes it has autolevelling and due to its extruder design its easy to print with more materials, like flexible thermoplastic (e.g. Filaflex)
3DVS
24
Thanks for your advices Jackson2727 and 3DPrinterPoint.
Have you used Simplify3D with the Witbox2 ?
I do use S3D with all my printers including WB1, WB2 and many others. The issue rely with working with the USB port currently. Other than that, SD works fine.
Not yet with wb2. With wb1 it went Fine so i think it will work Just Fine.
