Aug 2016
Hi, I’m new to 3D printing and am a volunteer in an amputee charity in Bolivia. We currently have had an Evolution 2nd Gen 3Dstuffmaker bought for our clinic with the aim to be able to make prosthetic hands for low income amputees in Bolivia. However…this printer is not really functioning as well as we’d like. If we try to print more than one part of a finger at a time it is really poor quality, the fan is inefficient, it will only use one type of material and fails regularly. We’re not sure if the altitude is partly responsible (we are 3600m above sea level). So I have a few questions if anyone can help:-
1) Would altitude affect print quality? Is there any recommendations as a way round this?
2) Would there be a better printer we could look into purchasing for this use at this altitude? We have a budget of between $500-$1000 to purchase a second one.
3) Any opinions on the Evolution range?
4) Any opinions on the Wanhoa range?
Thanks so much for your help.
Hi Amy,
Great project !!
We make use of Wanhao printers and they have been quite reliable. We have used the Wanhao 4s and the 4x.
If you are interested we have product that could further help you with your printing but I wont write about it here for the risk of being called a spammer :slight_smile:
If you are interested get in touch with me at keith@thought3d.com. We would be more than happy to support this cause!!
Best of Luck and happy printing.
Keith M
Hi Amy, I dont think altitude would affect quality (in basic terms, 3d printing is melting plastic and depositing it in the cartesian plane) but im happy to be corrected, with your budget I would look at some of the flashforge and makerbot clones or you could look at the prusa i3s
I can speak about the Wanhao i3 as I use it nearly every day for more than a year. They are very reliable machines if configured properly, you need to install mods also (parts you print to improve print quality / reliability, you will find a lot on thingiverse) and know about slicers. Depending on their size and geometry, each model you print will require slightly different settings, so being knowledgeable about slicers is mandatory. I don’t think altitude will have any impact.
Thanks for your reply, great that’s really useful to know as we will be using it a lot. Once it is set up will it require a knowledgeable user or could it be operated by most people once its been set up by a knowledgeable user?
Depends on the type of pieces. If you’re doing more or less the same kind of pieces (same geometry / size, infill etc) then an initial setup will be enough.
Excellent news. As all volunteers come and go so that is great to know. Thanks.
What material does it only print in? I’m going to guess it is PLA.
The altitude shouldn’t affect the print in any way that I can think of. Is it really humid where you live? If it is, the PLA can absorb the moisture from the air and that can affect print quality as the hot end vaporizes the water contained in the plastic while it extrudes.
As for getting a new printer, I would suggest getting a Prusa i3 kit. The Prusa i3 has the same build volume as the printer you currently have, and it is much more flexible and accessible to upgrades and such. Another plus is that there is no company-specific software associated with it. Just grab Cura or Slic3r to do the slicing, and move the generated gcode files directly to your machine!
Thanks.
