Old pla on the bed can cause serious adhesion problems for abs! Remove all the tape from your bed, clean your bed thoroughly, pla doesn’t dissolve in acitone so give it a good scrub, once all the pla is totally removed, clean the bed with acitone! Apply kapton / polyamide tape (preferably) then dissolve one inch of abs in 250ml of acitone to make a very weak “abs juice” … print bed should be 100 minimum … I use 110 and hot end will be 240ish (good abs comes with temp guide on packaging, done can be as low as 220)
