Feb 2016
Hello everyone,
I tried to print a Darth Vader pen cup using an Neofil 3D Black ABS and I obtained a strange result. It’s look like Warping but not at the buildplate interface (Buildtak at 90 °C). It seems to be a kind of Warping between every material layers…
My printer parameters was : Tnozzle = 260 °C, Tplate = 90 °C, Fan = 50 %, Flow = 107 %, Retraction = 4.50 mm
Did anyone already had this kind of problem ?
Thank you for your help,
Alexis
    Feb '16
    Feb '16
  • 17
  • 1.9k
  • 13
It looks like delamination are you using a enclosed printer? Changes in temperature / draughts can cause layers to split. You might also want to try lowering your temperature of the abs.I print abs at about 220-235 but that’s dependent on print speed and filament.
A tip:
Printing at lower temperatures is basically cheating to get the desired result. Layer adhesion will suffer, especially for larger prints like this. By the time the print heads gets back around to the same spot on the next layer, it’s had plenty of time to cool. It may work for a project like this, but if you were trying to print another project with similar dimensions that needed to be very strong in the Z axis, you will find that it will break easily, because you cheated and robbed the part of good layer adhesion.
-Enclosed printer, with high ambient heat, 110 print bed will still allow you to run fans in certain parts of the print for overhangs and details.
OK, all you " print at lower temp guys" Let me have it :slight_smile:
Something about temerature:
->You should print as hot as possible for good layer adhesion
->You should print as cold as possible for low cooling stress
If I print PLA I use temperatures at about 245…250°C. In My opinion that’s a good middle.
I know this problem all too well, although I have never had warping that extreme. I usually print ABS in the 240-250C range, with bed temp of 110C. Also turn your extruded fan off while printing. You want the temp of the extruded filament to drop as little as possible as slowly as possible. Rapid temp change will cause warping. Is your printer an open frame or is it enclosed? Did you have a fan on in the room or A/C?
Have you checked your Z-axis stepper motors? It looks like your buildplate might be jumping from time to time (skipping a layer by taking two or more steps downward) resulting to the sectioned layers. It might be because the power is fluctuating due to high temp requirement of the nozzle for printing on ABS. Solution wise, you can try lowering it down manually by 100 to 200 - also, it should not affect whenever you’re printing on PLA since it requires less nozzle heating.
Hello, thank’s for your answer.
The problem does not come from the Z axis in fact the infill is quiet good printed and to the “normal” level…
I am currently printing without fan and tommorow I will try by enclosing my printer.
I will send the result on this page.
