May 2016
I have checked it tomorrow, but all of the items you listed could not work with this problem.
I am trying to email you for twice, but got post-mail back. it looks like that I can’t send email to you. But I got yours.
I’ve recently started using a resurfaceable glass tank (z-vat) so have switched resins often. You don’t need to fully clean the tank each time you do it, using the scraper to carefully scrape the resin out is generally enough as I’ve not had trouble with the tiny bit of resin left mixing. I have experimented with cleaning the original tanks and it made them perform worse. I’ve had formlabs tanks fail well before they’re hit 2l resin which is why I got the glass tanks.
Hello, which kind of tank are you using now? or you just remove the silicone and add the glass in it? maybe I can do it too, I have already get two resin tank wasted, I can modify them.
