Printing at 25.microns?
Hi Winson, I have had the same problem. Contact to Formlabs Support helped. They are phantastic. You receive always step by step explanations.
Cheers
Alfred
How old is the resin tank? The resin tanks are good for 2L worth of resin and have to be replaced,even less if you keep putting a model in the same place on the build platform.
Yes, of course. They do touch the object in preform, but nothing come out on the finish good.
You can check the screenshots below, I let preform to orient my stl file and set the layer height at both 0.05mm and 0.025mm, in additional, I also added some supports based on the auto orientation, but both of them have been failed finally, I don’t know why.
Here are the pictures:
Thanks for the files, I will try to fix it by following the guideline from you.
What is the thickness of the walls of your model and how much use is on this particular resin tank?
Yes, I let preform to orient my samples. And i have cleaned the mirrors after every failure, but nothing help.
And I have printed this part with normal resin a few days ago, everything is okay even with the resolution of 0.025 is okay. But When i changed it to tough resin, it fails again and again, I don’t know how to deal with it. I have attached the screenshot of the orientation below, you can check it.
Anyway, thanks for your help.
actually it’s a new tank, when i used it for the first time, the printing failed then i change the orientation of the file and change to another position,but it failed again, and i have cleaned the tank after every failure, but nothing help. I have already send email to them but it’s Saturday, I can’t get feedback until this Monday.
Do you have skype, I would like to add you then that will be easier for me to get the suggestion from you. actually the wall thickness is enough for printing as i have printed this samples for nearly 3 times with normal white resin.
0.025 is not possible for tough resin, we can only choose 0.05mm and 0.1mm, and i have already tried 0.05 and 0.1, but none of them become successful.
how did they help you out? can you let me know? I will leave my skype to you, if it’s possible to add me and send me the guideline?
Skype ID: winson-qi
it’s only been used for 40ml, not that much, So i think maybe something wrong with it, I need to inspect.
By the way, have you used tough resin before, can you give me some picture of the tough resin?
I open the new bottle of resin and pour it into the tank for the first time, I saw some particles in it, here is the picture, I don’t know if it’s normal or not.
I apologize, I do not have Skype, sorry! Ok I think from what I’ve read, it narrows it down to your resin tank and dust on the mirrors. I would follow the Formlabs guide to cleaning all of the mirrors and you will definitely want to start with a fresh resin tank. After a few failures you will most likely have cloudiness in the tank. Also check your date on the back of the resin bottle to assure its not more than a year old.
Sorry I just saw your other pictures, those particles in the resin would definitely have caused your problems ! Anything blocking the laser would cause the issue that you are having. If you just purchased this resin I would contact Formlabs custom service because you may have gotten a bad bottle of resin.
Hello, can you just give me you email address? I will send email to you, that will be easier for both of us to conmunicate with each other.
winsonqi@126.com, this is my email address.
I sent you an email Winson.
marcmoirc@aol.com is my email. Hope I can help!
-Marc
Yeah I find the tough resin is very sensitive to tank cloudiness and mirror / galvo cleanliness. If you contact Formlabs support they’ll give you some things to try which might involve cleaning the mirror surfaces (don’t try any cleaning until you’ve spoken to them though!) Btw if your part has a flat bottom you might be able to get away with printing it flat on the build plate without supports…
Hello!
Be sure to clean your build Platform and your resin tank. It must be perfectly transparent or the laser will fail to polymerize. Also the mirror must be perfectly clean!
Remember to change your resin tank every 2 Lt of polymerized resin.
Let me know Let me know if there are any news.
Bye!!
Taking a picture with the flash on top of a photosensitive resin is definitely not recommended…
