Jan 2018
Hi Snoobler,
Thanks for your response, yep got my ABS-emitting alarm clock all set up now :wink:
Ah i see, and is that an enclosure you have built yourself? Or one you have purchased?
Many thanks
Vim
Hi Julie,
Many thanks for your comments, ah wow quite a fleet of printers!
OK I see, ah that’s a nice simple way to get rid of the smell. Does that work quite well then in terms of removing the smell of ABS?
Haha yes i have the same issue in getting headaches! Studies have shown that prolonged exposure at one time could make people feel dizzy or give them headaches. This doesn’t happen to everyone necessarily, however different people will feel different effects such as nausea, toxicity, irritation, or even nothing at all.
Also if you were interested here is a link to one of the studies I’ve been reading:
http://pubs.acs.org/doi/full/10.1021/acs.est.7b01454#showFigures 31
It basically details which filaments emit the most Nanoparticles, and details some advisory notifications as a result of the study.
Thank you Julie
Hi Bellair3D,
Thank you for your reply.
Ah i see, and do you notice any hint of smells at all with the enclosure working? Also which room is your Prusa i3 in can i ask?
Yes currently my research shows ABS many particles, which consists of Styrene and Ethylbenzene. They are linked to causing headaches, nausea and dizziness if you have prolonged exposure to it, so very wise to use the fan!
Also see the reply to Julie’s message for a little more detail on effects and there’s a link too to one of the studies ive been looking at. :slight_smile:
Many thanks
Vim
1. FormLabs Form2 (with 99% Isopropyl alcohol cleaning station)
2. 9’ x 13’ x 7’
3. None.
4. I am completely unconcerned with FDM filaments and whatever they off-gas, with resin printers I only care if the resin has a bad smell. Too many people need gluten-free or similar air. You should see the laser forums and anyone mentioning cutting PVC, you would think you are killing everyone in your house and all neighbors within 500’ if you laser cut a vinyl record.
27 days later
Yes.
I only print in PLA and PETG because of the toxins emitted by the other types of filament.
For those who say they print ABS, NYLON, PC, etc all the time and they’re fine, well yeah… today. Wait 20 years and then tell me how that worked for you. If you start smoking cigarettes today you’ll feel fine tomorrow too.
OK thank you for your answer.
Based on my research I agree with the long term effects that breathing in polluted air can give your body, especially your respiratory system.
So would you ever consider purchasing a 3D Printer Air Filter Accessory to help filter the majority of the particles emitted by 3D Printing with ABS, NYLON, PC, etc? (for an example product see this: Zimpure - Filtering solution for 3D Printers by Zimple — Kickstarter 39)
Thanks Mark for your help so far, it is helping with regards to my research! :slight_smile:
Best Regards
Vim
Hi Mark,
That is understandable because manufacturers could say anything!
Not so sure if you noticed or not, but the Zimple Zimpure product i sent in the link earlier has been tested by the LSCE (Laboratory of Sciences for Climate and Environment) in France. (not in any way am i trying to promote this product!)
See this link for their report: http://www.zimple3d.com/static/zimpure/study-report/Evaluation-of-an-innovative-filtration-system-for-Particulate-Matter-and-Volatile-Organic-Compounds-emitted-by-Desktop-3D-printers.pdf 19
regards
vim
