MetaCAD
January 14, 2016, 11:10am
5
TEMP LOW .REPLACE PTFE COUPLER AND USE FANS AT 20-50% IF ABS . IF PLA THEN FANS FULL BLAST
definitely orientation - spin it round to face the fan - that is what fixed mine (and dropping the temp to the lowest that the filament will print at.
Agreed. although you can get a better fan shroud off youmagine or thingiverse
JATMN
January 14, 2016, 4:13pm
8
Going to name a few things some have been mentioned some not… But they are the same suggestions I give all i3 owners as well as many other printers.
- First off printing PLA you -NEED- a good blower fan setup on the i3 (look into this one it will be your achilles heel if you dont have the right setup)
- Im going to assume you got your heated bed running due to the wrinkly defects on the lower portion of the print. Your heatbed temps are too high… lower them as low as you get get them… 50C and under… lower the better (35-40C range is ideal, but if your leveling and bed prep is off it will be harder to keep stuck to the bed so consider those factors and possibly adjust those as well).
- Looks like your printing temp is -slightly- high… lower that about 5-10C see if this helps.
What temps and speed are you extruding at?
Dear Friend,
Send me your STL file, I can help to print it and show you .
My email adds: yuki@zgew3d.com
oklok
January 15, 2016, 1:31pm
11
Suggestion
1.Try recalibrate so extruder is exact 1mm from heated bed
2. Print with support setting:touching bed.
3. Make sure extruder temp are in range
looks like printing too fast and z height is too high.
for a start try slowing it down to 25mm per second.
I get the same curling up on marvin’s rear end if I try to print him too fast and don’t allow the previous layers to cool.
N3DS
January 17, 2016, 9:19am
13
temp 185, fan 100%, speed 40
N3DS
January 17, 2016, 9:20am
14
0.4 nozzle, have tried printing at 0.1 layer and 0.2 height same result
Try 205c, 40 speed, 40-60c bed, fan 100% after 2nd layer. Are your temps fluctuating by more than 1-2c? How have you been storing your PLA? Ambient humidity? Would suggest trying to print something like 4 at a time to make sure the pieces cool before the next layer gets slapped on.
Make sure bed is covered in a light spray of hair spray for PLA if you want to print direct to the glass. Works flawlessly on my 4S.
Also may want to check out Jetguy on wanhao’s forums on google – fair warning, he’s a little irritable but he’s awesome too! Redirecting to Google Groups
A video or time lapse of this may also help…
Printing from SD not over USB right?
I had the same problem printing my first marvin with the back side layer adhesion. I tried it again with a slower speed and it worked fine, hope this helps!
N3DS
January 17, 2016, 8:44pm
19
Checked the temp and it is fluctuating 3-4c, seems to be a wekaness on the wanhao i3 v2, alot of people have same issue. Found a fix for it and will do it this weekend along with some other upgrades.
N3DS
January 17, 2016, 8:45pm
20
Thank you all for your suggeestions, I will do some upgrades on wanhao and tune some setttings, will post new pic`s of marvin once done.
N3DS
January 17, 2016, 8:50pm
21
Updating my fan to cover entire extruder
N3DS
22
I store my fillament in boxes covered with rice. Thanks for the link to google groups will check it out!
Dear, it is always true: price=quality=service . If you are interested in good quality 3d printer, I can recommend you JGAURORA 3d printer at below Aliexpress online store : http://www.aliexpress.com/store/1759640
A competitor recommending their own product?
You don’t find this tacky in any way?
