Chromate conversion coating services
Chromate conversion coating, more commonly known as chem film or by its brand name Alodine, is a type of conversion coating, used on aluminum as a corrosion inhibitor, as a primer for paint due to increased adherence or to preserve electrical conductivity.
Surface preparation Colors Applicable materials Thickness Cosmetic availability Visual appearance
As machined (Ra 3.2μm / Ra 126μin) Clear/ slight yellow tint Aluminum (7xxx series not recommended) None No Machining marks are visible
Bead blasted (Glass beads #120) Clear/ slight yellow tint Aluminum (7xxx series not recommended) None Cosmetic on request Machining marks are completely removed on “cosmetic” parts but may be visible on “non-cosmetic” parts
Example of chromate conversion coated parts
Chromatic Conversion Coating
Design considerations for chromate conversion coating:
  • When applying chromate conversion coating, the dimensions of the part can be controlled, enabling it to maintain the requested tolerances.
  • Chromate conversion coating can be applied to aluminum alloys, however, steel and iron parts cannot be coated directly.
What is chromate conversion coating?
Chromate conversion coating is a chemical coating for metal that has many benefits. It protects aluminum from corrosion, serves as a primer for painting and preserves electrical conductivity, making it a useful finish for parts used in the aerospace, automotive and construction industries. At Hubs, we only use chromium-free, RoHS-compliant chromate conversion coating.
How does chromate conversion coating work?
Chromate conversion coating involves adding chromic acid to a metal in a chemical process that results in a thin, protective outer layer. This enhances a metal’s durability and makes it more resistant to corrosion.
Protolabs Network offers chromate conversion coating for aluminum parts to improve functional properties. To find out more, contact networksales@protolabs.com
Here’s how we apply chromate conversion coating:
  • Parts are cleaned and degreased to remove any contaminant
  • Parts are then rinsed to eliminate any residue of detergent
  • Aluminum parts are immersed in a tank containing the chemical solution
  • Parts are removed when a film of the desired thickness coats the surface
  • Parts are then rinsed again
Put your chromate conversion coated parts into production today
