Surface finishing service
The easiest way to source your custom parts, with 15+ surface finishing options. Get your parts bead blasted, anodized, or powder coated.
Name
Service
Applicable to
Machining marks
Cosmetic availability
Tolerances
CNC machining, Sheet metal fabricat ion
Metals, Plastics
Visible, light surface scratches
No
Tolerances are not affected
Metals, Plastics
No
Slightly visible
No
Removed on primary surfaces
Always cosmetic
Met after polishing
Bead blasting
CNC machining, Sheet metal fabrication
Removed for non-cosmetic, removed on primary surfaces for cosmetic
On request
Not affected except for specific features*
Brushing
Reduced for non-cosmetic, removed on primary surfaces for cosmetic
On request
Met after brushing
Anodizing Type II
On request
Met after anodizing
Anodizing Type III
Visible under anodizing
No
Met after anodizing
Copper, Stainless steel, Alloy steel, Tool steel, Mild steel
Visible
No
Met after coating
Chromate conversion coating
Visible
No
Met after coating
Electroless nickel plating
Mild steel, Aluminum, Stainless steel
Reduced but visible
No
Met after electroless nickel plating
Powder coating
Removed
No
Met before powder coating
Brushed + electropolishing
Removed on Primary surfaces
Always cosmetic
Met after electropolishing
Vapor smoothing
Surface gets a smooth glossier appearance
No
Met before vapor smoothing
Cosmetic finishes
Surface finishes can serve either a functional or aesthetic purpose. Surface finishes that serve both purposes are deemed cosmetic finishes, and are used for cosmetic parts. Producing cosmetic parts requires additional measures to minimize defects such as hang marks and scratches from tools.
Parts with non-cosmetic finish
Non-cosmetic
Primary machining marks will still be visible
  • As machined
  • Smooth machining
  • Fine machining
  • Chromate Conversion Coating
  • Electroless Nickel Plating
  • Anodized type III (Hardcoat)
  • Powder coating
  • Black oxide
Example of parts with cosmetic surface finish on request
Cosmetic on request
Finishes can be either cosmetic or non-cosmetic as per request
  • Brushed + Anodizing type II
  • Bead Blasted + Anodizing type II
  • Bead Blasted
  • Brushed
Example of part with default cosmetic surface finish
Cosmetic by default
These finishes will always serve a cosmetic function
  • Brushed + Electropolished
  • Polishing
Defining an A and a B side
Surface finishing often leaves aesthetic defects on your parts, such as hang marks for anodizing. Defining an A- and a B-side in your design will ensure that the most important areas of your part remain free of defects.
In this image you can see how you can define an A-side and a B-side in your technical drawing:
A side: Indicates the most aesthetically important surface, typically the visible side of your product.
B side: Indicates the side that is not aesthetically important, typically the side hidden from visibility after assembly.
For the primary surface (A-side) of your part, we guarantee defect-free production. In contrast, secondary surfaces (B-side) may be machined with hanging marks and other minor defects. B-side surfaces, like the rest of your part, will be free of scratches, stains and blemishes.
Will my part have Primary surface
(A-side)
Secondary surface
(B-side)
Scratches, stains, blemishes No No
Hanging marks No Minor hanging marks
Other minor defects No Up to 2 minor defects
Cosmetic Acceptability Criteria
All cosmetic parts produced by Protolabs Network follow our Cosmetic Acceptability Criteria:
Consistency requirement illustration
Consistency requirements
Each part must be visually consistent across the same batch, meaning:
  • Same grit must be used across parts for sanding or brushing
  • Brush marks must be in the same direction**
  • Color must be consistent to the same pantone when parts are placed next to each other
  • Gloss units must be consistent across the batch
*** Manual brushing marks will be as unidirectional as possible. Please note that for rounded geometries, brushing marks may not be entirely unidirectional.*
Observation condition illustration
Visual inspection conditions
The surface quality of every part must meet the following conditions:
  • Distance: 50cm ±10cm (19,7 in ± 3,9 in) with a 10/10 vision (or corrected)
  • Incidence angle: Approximately 45º in all directions
  • Lighting conditions: 500-1000 Lux, color 3300-5300 Kelvin (neutral white)
What do you need to know about cosmetic finishes?
  • Cosmetic finishes will follow our Cosmetic Acceptability Criteria
  • Parts will have guaranteed consistency across the batch
  • Batch will be inspected as per AQL level II
  • There will be around a +10% price increase
Put your parts into production today
