Standard Blank Sizes for CNC machining (Sheets & Rods)
The “blank” in CNC machining is the piece of material (metal or plastic) that is initially loaded to the machine. Stock materials come as plates (for CNC milling) or rods (for CNC turning) in a variety of sizes. In the tables below we summarize the most common blank dimensions found in a typical machine shop.
Note: 0.3 mm to 1.5 mm of material will be removed from each side of the blank during machining (that is up to 3 mm total). This should be taken into account during design as the blank size can significantly increase the material cost for large-scale productions.
Plates
Stock plates come pre-cut to size or as large sheet (typically, 2 m by 1 m - 6 ft. by 3 ft.) that are cut to blanks by the machine shop. So, the limiting dimension for a plate when it comes to design is its thickness.
The table below summarizes the most common aluminum and steel plate thicknesses that can be found in the warehouse of every machine shop. For an extensive, refer to a material supplier catalog.
Thickness [mm] Thickness [inches]
3 mm 3/16''
4 mm 1/4''
5 mm 5/16''
6 mm 3/8''
8 mm 7/16''
10 mm 1/2''
12 mm 5/8''
15 mm 3/4''
20 mm 1''
25 mm 1/2'' increase therafter (up to 5'')
30 mm
10 mm increase thereafter (up to 100 mm)
Rods
Rods come as long stock (typically, 1 m - 3 ft. - or longer) that are cut to blanks by the machine shop. The limiting dimension here is the diameter of the rod.
Diameter [mm] Diameter [inches]
3 mm 1/8''
4 mm 3/16''
5 mm 1/4''
6 mm 5/16''
7 mm 3/8''
8 mm 7/16''
9 mm 1/2''
10 mm 5/8''
12 mm 3/4''
14 mm 7/8''
15 mm 1''
16 mm 1/4'' increase therafter (up to 3'')
20 mm
25 mm
30 mm
40 mm
10 mm increase therafter (up to 100 mm)
What are countersinking holes and how do you use them?
Understanding tapped vs. rolled threads
Rz vs Ra roughness
Certifications mockup for the knowledge base article
Different types of quality documentation and when you need them
Countersinking holes are conical holes designed to seat the head of a screw, bolt, or fastener so it sits flush with or just below the surface. This keeps the part’s outer layer smooth, which can improve its appearance, safety and performance. In this guide, we’ll drill into the ins and outs of countersinking, covering methods, applications, pros and cons, and tips for getting it just right.
What are tapped and rolled threads, and what do engineers need to know about them to manufacture high-performance parts? Find out here.
Rz vs Ra roughness
Learn about the role quality documentation plays in the manufacturing process, how to obtain it, and the types of documentation that apply to parts, materials, and more
Have you designed your parts with sharp corners? They may look good on paper, but they're a nightmare to manufacture with CNC machining. In this article, learn how and why to avoid sharp corners in your designs. It'll reduce lead times, cost and potential headaches for machinists.
