Design for CNC machining
CNC (computer numerically controlled) machining is a robust and high-precision process for manufacturing custom parts. Optimizing the way you design parts can help you get more out CNC's range of milling and turning solutions. This section provides design guidance for reducing costs, speeding up machining times and ensuring parts get produced to your specifications. Learn how to design parts to get the most out of CNC.
Have you designed your parts with sharp corners? They may look good on paper, but they're a nightmare to manufacture with CNC machining. In this article, learn how and why to avoid sharp corners in your designs. It'll reduce lead times, cost and potential headaches for machinists.
