CNC machining service UAE
Online CNC machining in UAE
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in UAE
CNC Turning in UAE
CNC surface finishing in UAE
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 267 customers are satisfied with our CNC Machining service.
“Decent, as expected within the timeframe”
Fanis Kalliontzis, Afidnes
“It was well made and within the actual tolerances. I would definitely order again.”
Emir Goletic, Espoo
“Great”
Fabian Baumann, Berlin
“amazing”
ABS, CNC machining
“Great”
Stefan Wunder, Bretzfeld
Aluminum 7075, CNC machining
“Looks very nice, all measurements are correct”
Fredrik Paulsson, Sundsvall
“Quick and to specifications with a vast choice of material to choose from and many file formats supported.”
Julien Dumas-Pilhou, Geneva
“Looks great and the price was good”
Andreas Bengtsson, Göteborg
“high service and support quality. nice”
Rüdiger Ostholt, Wetter
“The quality and the precision of the parts are surprisingly fine”
Santi Julià, Palol de Revardit
“Everything looks good”
Jusong Choe, Oslo
“Good and fast communication. Prompt quotion. Parts (milled) were made and delivered in 10 days after ordering. Excellent Quality.”
Pieter Visser, Lith
“Excellent dialog, excellent work”
Alan URBAN, Bruxelles
“Great experience . Great work.”
christophe ghewy, 2018
“After fighting for years with local providers, the network has been my salvation. Parts are of high quality.”
Ivan Perino, Valencia
“Excellent quality and accuracy”
Henk van der Meijden, Midrand
Delrin, CNC machining
“The service was done at a good quality with a reasonable price. Fast delivery as expected”
Jean-Michel Hubert, ST GERMAIN EN LAYE
“Fast service at a resonable price”
“Very quick y within the tolerances.”
Jose Manuel Pérez Escudero, Pamplona
“Easy to use, quick service and the fabrication within the tolerance”
Jose Manuel Perez, Pamplona
“The parts we ordered were simple but in any case the finishing was good. We will order more complex parts in the future.”
Carlos Fernandez, Boadilla del Monte
“good quality and excellent delivery time”
Lee Kenny, Sheffield
Aluminum 6082, CNC machining
“good quality, as expected.”
Martin Foster, freeth street
“Parts were made at a reasonable cost and arrived on time.”
Jeff Prest, Burnley
PVC, CNC machining
“All parts arrived on time and were accurate to the drawings and 3D files provided. Very impressed with the service”
Ben Fowler, Livingston
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
