CNC machining service South Dakota
Online CNC machining in South Dakota
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in South Dakota
CNC Turning in South Dakota
CNC surface finishing in South Dakota
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 145 customers are satisfied with our CNC Machining service.
“we are very impressed and working on an order for 100 more pieces in Sept. thank you!!”
James Ellenwood, RAPID CITY
“great quality”
jamie Ellenwood, RAPID CITY
“love your service and parts”
Jamie Ellenwood, Rapit City
“Amazing quality for a great price”
Jason Millard, rapid city
Alloy steel 4340, CNC machining
“Done right in a timely fashion”
“Amazing quality for the price”
“Accurate and affordable”
Brass C360, CNC machining
“Awesome quality awesome speed time frame”
Jason Millard, RAPID CITY
Aluminum 6082, CNC machining
“Good parts as expected”
Pratheen Barthiban, Waverly
“Form, fit and function are as intended. Quick turn around time.”
Joshua Lind, North Liberty
Kyle Janny, Lake Mills
“Fit, finish and function are perfect.”
Dennis Brady, Waxahachie
“The part was flawless.”
Kris Steward, Cordova
“Great price”
Brandon Sweeney, Pflugerville
“Parts were perfect. Delivery was prompt. Great experience.”
Leonard Haberman, Cypress
Alloy steel 4140, CNC machining
Dragan Vukovic, Smyrna
ABS, CNC machining
“Excellent. Could not be happier. Exceptional work.”
DANIEL CLARKE, Calgary
“I like how they were able to quickly sourced my parts at good rate and followed up with manfacture to ensure quality of the parts.”
Majed Affan, Calgary
“The quality of the parts matched my expectations.”
Igor Ganakovsky, Calgary
Aluminum 7075, CNC machining
“Very good part.”
Moxuan Li, Columbus
David Morar, Canton
“Part looked fantastic”
Cory Kunkel, Mentor
“Good job overall”
“Great”
Adam Latour, Toronto
Ultem 1000, CNC machining
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
