CNC machining service South Africa
Online CNC machining in South Africa
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in South Africa
CNC Turning in South Africa
CNC surface finishing in South Africa
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 297 customers are satisfied with our CNC Machining service.
“Excellent quality and accuracy”
Henk van der Meijden, Midrand
Delrin, CNC machining
“Decent, as expected within the timeframe”
Fanis Kalliontzis, Afidnes
“After fighting for years with local providers, the network has been my salvation. Parts are of high quality.”
Ivan Perino, Valencia
“The quality and the precision of the parts are surprisingly fine”
Santi Julià, Palol de Revardit
“The parts we ordered were simple but in any case the finishing was good. We will order more complex parts in the future.”
Carlos Fernandez, Boadilla del Monte
“Very quick y within the tolerances.”
Jose Manuel Pérez Escudero, Pamplona
“Easy to use, quick service and the fabrication within the tolerance”
Jose Manuel Perez, Pamplona
“Quick and to specifications with a vast choice of material to choose from and many file formats supported.”
Julien Dumas-Pilhou, Geneva
Aluminum 7075, CNC machining
“Great”
Stefan Wunder, Bretzfeld
“The service was done at a good quality with a reasonable price. Fast delivery as expected”
Jean-Michel Hubert, ST GERMAIN EN LAYE
“Fast service at a resonable price”
“high service and support quality. nice”
Rüdiger Ostholt, Wetter
“amazing”
Fabian Baumann, Berlin
ABS, CNC machining
“Great”
“Excellent dialog, excellent work”
Alan URBAN, Bruxelles
“Great experience . Great work.”
christophe ghewy, 2018
“Good and fast communication. Prompt quotion. Parts (milled) were made and delivered in 10 days after ordering. Excellent Quality.”
Pieter Visser, Lith
“good quality, as expected.”
Martin Foster, freeth street
“good quality and excellent delivery time”
Lee Kenny, Sheffield
Aluminum 6082, CNC machining
“Parts were made at a reasonable cost and arrived on time.”
Jeff Prest, Burnley
PVC, CNC machining
“Looks great and the price was good”
Andreas Bengtsson, Göteborg
“It was well made and within the actual tolerances. I would definitely order again.”
Emir Goletic, Espoo
“Exactly what was ordered. Great finish on the product aswell.”
Thomas Egan, Galway
“All parts arrived on time and were accurate to the drawings and 3D files provided. Very impressed with the service”
Ben Fowler, Livingston
“Brilliant”
Stuart leslie, COLERAINE
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
