Hubs is now Protolabs Network. Find out more
CNC machining service Rhode Island
Online CNC machining in Rhode Island
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in Rhode Island
CNC Turning in Rhode Island
CNC surface finishing in Rhode Island
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar
Invar
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar
Invar is a nickel alloy with a very low coefficient of thermal expansion. Ideal for applications where high dimensional stability is required, such as precision instruments, engines valves and large aerostructure molds.
Alloys
Invar
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Production
Over 146 customers are satisfied with our CNC Machining service.
David Brownell, Medfield
Eugene Degre, Worcester
Jamison Go, Burlington
Aluminum 7075, CNC machining
Michael Keenan, Yaphank
“parts looked great”
“Quick turn around - Quality precision - Above my expectations”
Chris Szente, Oxford
David Reinhardt, Monmouth Junction
Yuriy Mirochnik, Huntigdon Valley
“Good job.”
Eric Gauthier, Trois-Rivieres
WILLIAM MEREDITH, Ottawa
Brass C360, CNC machining
“My parts were perfect!”
Andrew Stowell, Hagerstown
“Great”
Adam Latour, Toronto
Ultem 1000, CNC machining
“Good job overall”
“Great price, good quality.”
Andrew Priest, Apex
“Part looked fantastic”
Cory Kunkel, Mentor
David Morar, Canton
Mark Rose, Conway
“Very good part.”
Moxuan Li, Columbus
Dragan Vukovic, Smyrna
ABS, CNC machining
“Absolutely perfect!”
Bobby Watts, Winter Garden
Kyle Janny, Lake Mills
“Very good service and food quality.”
Andrew Bliesner, Miami
“The part was flawless.”
Kris Steward, Cordova
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
