Give us a chance to beat your quote
On-demand CNC machining service for rapid prototyping and production parts, through a network of specialized, experienced and thoroughly vetted local and global CNC machine shops.
Get instant quote Our capabilities
Our CNC machining service capabilities
CNC machine all types of parts, from simple “as machined” workholdings to complex geometries. Our manufacturers operate almost every kind of CNC mill and turning center, with EDM and grinders available on request. We offer tolerances down to ±.020 mm (±.001 in) and lead times from 5 business days.
3 & 5 axis CNC milling CNC machined part, CNC milling, anodized surface finish
Access over 1,000 milling centers, including standard 3-axis mills, indexed 3+2-axis mills & fully-continuous 5-axis mills
Access over 300 turning centers, including Swiss lathes and multi-axis mill turns.
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Specialist industries
We’ve manufactured millions of parts for all sorts of applications, but we’re especially knowledgeable in these areas.
Aerospace & aviation
Aerodynamic parts for aircraft, drones, satellites and rockets with AS 9100 certification.
Read more
Medical Image representing medical industry
Medical
Create custom medical devices and diagnostic equipment to get healthcare innovations into hospitals and homes.
Read more
Automotive
Automotive
Fast-tracked development for electric vehicles and other automotive innovations.
Read more
Robotics & automation Image representing robotics industry
Produce complex robotic systems, end effectors and automated machinery for this innovative industry.
Read more
Hone Shaving: Manufacturing High-quality Shaving Products
Watch how the founder of Hone Shaving, Andrew Mitchell, tells the story of how he created his unique and high-quality razors with the help of Protolabs Network.
Watch it here
Get complete program management from our team of experts to optimize cost, quantity, and quality control of production orders for end-use parts. Find out about manufacturing higher volumes at reduced part costs, our commitment to quality and expanded capabilities to support with scaling to production.
Explore production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
  • Lead times from 5 business days
