Black anodized and silk screening
Part Marking Service
Get your custom CNC machined parts marked with laser engraving or silk screening.
Get instant quote Part marking capabilities
Laser engravingSilk screeningPart tagging
What is part marking?
Part marking is a cost-effective way to add logos or custom lettering to your designs and is often used for custom part tagging during full-scale production.
To request part marking, you will need to provide the following:
  • 3D model of the part
  • Vector file (typically in AI format) of the font or geometry required for the marking
  • Technical drawing (PDF format) indicating the exact location for the marking
Do you have your vector file ready? Request a quote here or contact us directly.
Logos and lettering
Laser engraving and silk screening are two cost-effective techniques that allow for greater flexibility with your design. They are a great option for logos and lettering that are difficult to produce with manufacturing alone.
Typically it is also much more cost-effective to mark a part instead of designing the logo or lettering as part of the model, especially where sharp corners are required.
Part tagging
Part tagging involves marking the parts with incremental serial numbers to allow for traceability. This is typically used for end parts.
Our part marking capabilites
Part marking is available for all orders using either laser engraving or silk screening. For more information or to request a quote, please contact your Account Manager or send us an email.
Laser engraving (laser etching)
Laser engraving is fast and precise. It provides durable marking that does not wear over time, commonly used for serial numbers.
The color of the engraving is typically the natural color of the raw material.
Silk screening
Silk screening is an inexpensive option for marking parts. It allows for a wide range of color options, which can be indicated with either a Pantone or RAL number.
Put your parts into production today
