CNC machining service North Carolina
Online CNC machining in North Carolina
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in North Carolina
CNC Turning in North Carolina
CNC surface finishing in North Carolina
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 309 customers are satisfied with our CNC Machining service.
“Great price, good quality.”
Andrew Priest, Apex
Mark Rose, Conway
“My parts were perfect!”
Andrew Stowell, Hagerstown
David Morar, Canton
“Very good part.”
Moxuan Li, Columbus
“Part looked fantastic”
Cory Kunkel, Mentor
Yuriy Mirochnik, Huntigdon Valley
Dragan Vukovic, Smyrna
ABS, CNC machining
David Reinhardt, Monmouth Junction
“Absolutely perfect!”
Bobby Watts, Winter Garden
“Good job overall”
“Great”
Adam Latour, Toronto
Ultem 1000, CNC machining
“parts looked great”
Michael Keenan, Yaphank
“Very good service and food quality.”
Andrew Bliesner, Miami
“The part was flawless.”
Kris Steward, Cordova
Eugene Degre, Worcester
WILLIAM MEREDITH, Ottawa
Brass C360, CNC machining
David Brownell, Medfield
Jamison Go, Burlington
Aluminum 7075, CNC machining
Kyle Janny, Lake Mills
“Quick turn around - Quality precision - Above my expectations”
Chris Szente, Oxford
“Good job.”
Eric Gauthier, Trois-Rivieres
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
