3-, 4- & 5-axis milling
Lead times from 5 business days
Get an instant CNC quote All uploads are secure and confidentialProtolabs Network uses state-of-the-art technology to bring custom CNC machining online. We work with a large network of manufacturing partners that together have over 1,600 milling and turning machines, which means we always have capacity and very competitive prices. It also means we can produce both complex prototypes and low-volume production runs of precision machined parts, in a broad range of metals and plastics and with many surfaces finishes too. It’s like having an entire supply chain team for free.
60+ metals & plastics, including 10+ aluminum & 20+ steel
Here’s a small selection of the CNC machined prototypes and end-use parts we’ve produced for our customers.
Bead Blasted + Anodized type III
As machined + Anodized type III
Upload a CAD to start (STEP, STP, IGES, IGS, SLDPRT, 3DM, SAT, STL, OBJ or X_T)
Price updates in real-time as you change materials, lead time, etc..
No hidden costs. Our instant quotes are not just indications, but the actual price, and include shipping and customs up front.
Invar
“Quick turn around - Quality precision - Above my expectations”
“parts looked great”
“Good job.”
“My parts were perfect!”
“Great”
“Good job overall”
“Part looked fantastic”
“Great price, good quality.”
“Very good part.”
“Absolutely perfect!”
“Very good service and food quality.”
“The part was flawless.”
Learn moreOur platform accelerates prototyping development cycles by reducing pre-production admin from weeks to minutes:
Instant quotes
Instant DFM feedback
Online quote and order management
Live delivery tracking
Dedicated project managers in your time zone
Application engineers for DFM cost optimizations
First Article Inspection (FAI)
We have an incredibly broad range of capabilities–much more than most individual shops.
In most cases our quotes are instant. Request as many quotes as you like to find the best solution for your project.
There is no minimum order quantity.
We can scale with you from quick-turn prototypes with 1-day lead times to millions of production parts with volume pricing.
We leverage a global network to guarantee competitive pricing on every order.
At Protolabs Network we offer CNC milling (3-axis, 3+2-axis and 5-axis) and turning. Milled parts can be machined up to 2000 x 1500 x 200 mm (78.7 x 59.0 x 7.8 in.) for 3/3+2 axis CNC milling. For 5-axis milling, the maximum part size is 650 x 650 x 300 mm (25.5 x 25.5 x 11.8 in.). The maximum diameter for CNC turning is 431mm (17 in.), length 990 mm (39 in). Minimum part dimensions recommended are around 0.39 x 0.39 x 0.39 in. (10 x 10 x 10mm).The minimum for feature dimensions is 0.5 mm.
25+ plastics & 35+ colors
±0.5% dimensional accuracy with a lower limit down to ±0.0059 in (0.15 mm)
Lead times from 1 business day
Tolerances down to ±0.1 mm (±.004 in)
Wide range of part complexities and sizes
1 to 1M parts
