Hubs is now Protolabs Network. Find out more
CNC machining service DC
Online CNC machining in DC
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in DC
CNC Turning in DC
CNC surface finishing in DC
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar
Invar
Alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar
Invar is a nickel alloy with a very low coefficient of thermal expansion. Ideal for applications where high dimensional stability is required, such as precision instruments, engines valves and large aerostructure molds.
Alloys
Invar
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Production
Over 169 customers are satisfied with our CNC Machining service.
“My parts were perfect!”
Andrew Stowell, Hagerstown
Yuriy Mirochnik, Huntigdon Valley
David Reinhardt, Monmouth Junction
“Great price, good quality.”
Andrew Priest, Apex
“parts looked great”
Michael Keenan, Yaphank
David Morar, Canton
“Part looked fantastic”
Cory Kunkel, Mentor
“Great”
Adam Latour, Toronto
Ultem 1000, CNC machining
“Good job overall”
Mark Rose, Conway
“Very good part.”
Moxuan Li, Columbus
Eugene Degre, Worcester
WILLIAM MEREDITH, Ottawa
Brass C360, CNC machining
David Brownell, Medfield
Jamison Go, Burlington
Aluminum 7075, CNC machining
“Quick turn around - Quality precision - Above my expectations”
Chris Szente, Oxford
“Good job.”
Eric Gauthier, Trois-Rivieres
Dragan Vukovic, Smyrna
ABS, CNC machining
“Absolutely perfect!”
Bobby Watts, Winter Garden
Kyle Janny, Lake Mills
“The part was flawless.”
Kris Steward, Cordova
“Very good service and food quality.”
Andrew Bliesner, Miami
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
  • 25+ plastics & 35+ colors
