CNC milling service
Source custom parts with our CNC milling services provided by our network of specialized manufacturers. Source custom CNC milling parts using more than 50 different metals and plastics, available in more than 15 surface finishes. Tolerances down to ±.0008"
What is CNC milling?
CNC milling uses rotational cutting tools to remove material from a workpiece to produce finished parts and products. This manufacturing process works well for many materials, including metals, polymers, wood and glass. CNC milling systems generally have 3 linear degrees of freedom: the X, Y and Z axis. This allows for top-notch precision and detailing. Protolabs Network also offers more advanced, 5-degree systems, where the tool head and machining bed (A and B axis) can also rotate. 5-axis CNC machines can produce parts with high geometric complexity without needing multiple machine setups.
Learn more about CNC milling and turning
Maximum part size for 3- and 3+2-axis CNC milling
There are several types of CNC milling machines, each with its own distinct maximum part size. 3-axis and 3+2 axis machines have the lowest start-up costs and can produce parts with relatively simple geometries.
3-axis milling
Size Metric units Imperial units
Max. part size for soft metals [1] & plastics 2000 x 1500 x 200 mm 1500 x 800 x 500 mm 78.7 x 59.0 x 7.8 in 59.0 x 31.4 x 27.5 in
Max. part for hard metals [2] 1200 x 800 x 500 mm 47.2 x 31.4 x 19.6 in
Min. feature size Ø 0.50 mm Ø 0.019 in
[1] : Aluminum, copper & brass [2] : Stainless steel, tool steel, alloy steel & mild steel
3+2 axis milling
Max. part size for soft metals [1] & plastics 2000 x 1500 x 200 mm 78.7 x 59.0 x 7.8 in
[1] Aluminum, copper & brass [2] Stainless steel, tool steel, alloy steel & mild steel
Maximum part size for 5-axis CNC milling
The more advanced of the milling machine family, 5-axis centers can produce parts with more complex geometries. These machines require fewer machine setups so they are more productive.
Max. part size for all materials 2000 x 1500 x 200 mm 78.7 x 59.0 x 7.8 in
Available materials for CNC milling
Example of CNC milling metals
A wide range of metals for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
Example of CNC milling plastics
A wide range of plastics for CNC machining, with applications in multiple industries. Ideal for both one-off prototypes and end-use custom parts.
CNC milling surface finishes
Improve your part’s performance by selecting high-quality surface finishes that enhance the roughness, hardness, chemical resistance and cosmetic features of your finished component.
Browse CNC milling surface finishes
CNC milling tolerances
We follow ISO 2768 standards for CNC machining.
Limits for nominal size Plastics (ISO 2768- m) Metals (ISO 2768- f)
0.5mm* to 3mm ±0.1mm ±0.05mm
Over 3mm to 6mm ±0.1mm ±0.05mm
Over 6mm to 30mm ±0.2mm ±0.1mm
Over 30mm to 120mm ±0.3mm ±0.15mm
Over 120mm to 400mm ±0.5mm ±0.2mm
Over 400mm to 1000mm ±0.8mm ±0.3mm
Over 1000mm to 2000mm ±1.2mm ±0.5mm
Over 2000mm to 4000mm ±2mm
*Please clearly indicate tolerances for nominal sizes below 0.5mm on your technical drawing.
CNC milling design guidelines
Check the recommended and technically feasible values for the most common features encountered in CNC machined parts.
Learn more in our engineering guide to CNC machining
Feature Recommended size Feasible size
Min. feature size Ø 2.5 mm Ø 0.50 mm
Internal edges R 8 mm R 0.25 mm
Minimum wall thickness 0.8 mm (for metals) 1.5 mm (for plastics) 0.5 mm (for metals) 1.0 mm (for plastics)
Holes Diameter: standard drill bit sizes
Depth: 4 x diameter
Diameter: Ø 0.5 Depth: 10 x diameter
Threads Size: M6 or larger Length: 3 x diameter Size: M2
Why should you choose CNC milling?
We have high standards for CNC milling
We manufacture your custom parts according to strict manufacturing standards and ensure all parts and processes adhere to The Protolabs Network Standard.
  • Every custom part gets checked on site by our manufacturing partners according to our guidelines.
  • Inspection reports and other types of quality documentation are available on request to assure the highest quality and compliance.
More resources for CNC milling
Learn more about how our CNC milling service works and how to design parts to get the most out of this machining process.
