Access over 1,000 milling centers, including standard 3-axis mills, indexed 3+2-axis mills & fully-continuous 5-axis mills
CNC machining service online
On-demand CNC machining service for rapid prototyping and production parts, through a network of specialized, experienced and thoroughly vetted local and global CNC machine shops.
Get instant CNC machining quote All uploads are secure and confidentialOur CNC machining service capabilities
CNC machine all types of parts, from simple “as machined” workholdings to complex geometries. Our manufacturers operate almost every kind of CNC mill and turning center, with EDM and grinders available on request. Protolabs Network (formerly Hubs) offers tolerances down to ±.020 mm (±.001 in) and lead times from 5 business days.
Access over 300 turning centers, including Swiss lathes and multi-axis mill turns.
Learn moreOur ordering process
Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T651 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6082-T651 | 3.2315 | 64430 | AlSi1MgMn Aluminum 6060 | 3.3206 | AlMgSi Aluminum 5052 | EN AW-5052 | 3.3523 | AlMg2,5 Aluminum 2017A | 3.1325 | 24530 | AlCu4MgSi Aluminum 2014 | 3.1255 | 24345 | AlCu4SiMg Aluminum 6063 | EN AW-6063 | 62400| AlMg0,7Si Aluminum 7050 | EN AW-7050 | 3.4144| AlZn6CuMgZr Aluminum 2024-T351 | 3.1355 | 24530 | AlCu4Mg1 Aluminum MIC6 Aluminum 7075-T6 | 3.4365 | 76528 | AlZn5,5MgCu Aluminum 5083-H111 | 3.3547 | 54300| AlMg4.5Mn0.7 Aluminum 6082 | 3.2315 | 64430| AlSi1MgMn Aluminum 6061-T6 | 3.3211| 65028| AlMg1SiCu Show all alloys
Invar 36
Bead Blasted + Anodized type III
As machined + Anodized type III
Learn moreManufactured through Protolabs Network
Get complete program management from our team of experts to optimize cost, quantity, and quality control of production orders for end-use parts. Find out about manufacturing higher volumes at reduced part costs, our commitment to quality and expanded capabilities to support with scaling to production.
Explore production
Specialist industries
We’ve manufactured millions of parts for all sorts of applications, but we’re especially knowledgeable in these areas.
Aerodynamic parts for aircraft, drones, satellites and rockets with AS 9100 certification.
Read moreCreate custom medical devices and diagnostic equipment to get healthcare innovations into hospitals and homes.
Read moreFast-tracked development for electric vehicles and other automotive innovations.
Read moreProduce complex robotic systems, end effectors and automated machinery for this innovative industry.
Read moreGallery of CNC machined parts
Here’s a small selection of the CNC machined prototypes and end-use parts we’ve produced for our customers.
Why choose Protolabs CNC machining
We use automation to make custom machining easier, faster and more affordable than traditional machine shops:
We have an incredibly broad range of capabilities - much more than most individual shops.
Our quotes are generated instantly - request as many quotes as you like without feeling guilty.
No limits on order size - we can scale with you from one-off prototypes to millions of production parts.
We leverage market forces within our network to guarantee competitive pricing on every order.
We machine rapid prototypes and low-volume production orders for customers in multiple industries: aerospace, automotive, defense, electronics, hardware startups, industrial automation, machinery, manufacturing, medical devices, oil & gas and robotics.
Hone Shaving: Manufacturing High-quality Shaving Products
Watch how the founder of Hone Shaving, Andrew Mitchell, tells the story of how he created his unique and high-quality razors with the help of Protolabs Network.
At Protolabs Network we offer CNC milling (3-axis, 3+2-axis and 5-axis) and turning. Milled parts can be machined up to 2000 x 1500 x 200 mm (78.7 x 59.0 x 7.8 in.) for 3/3+2 axis CNC milling. For 5-axis milling, the maximum part size is 650 x 650 x 300 mm (25.5 x 25.5 x 11.8 in.). The maximum diameter for CNC turning is 431mm (17 in.), length 990 mm (39 in). Minimum part dimensions recommended are around 0.39 x 0.39 x 0.39 in. (10 x 10 x 10mm).The minimum for feature dimensions is 0.5 mm.
25+ plastics & 35+ colors
±0.5% dimensional accuracy with a lower limit down to ±0.0059 in (0.15 mm)
Lead times from 1 business day
Tolerances down to ±0.1 mm (±.004 in)
Lead times from 5 business days
Wide range of part complexities and sizes
1 to 1M parts
Need corrosion protection without adding bulk? Request a free, instant quote and upload your CAD for real‑time pricing on your CNC part.
